Passive Filter (High Pass) for Sub Question
Discussion in 'Archived Threads 2001-2004' started by Anthony AC, Mar 12, 2003.
  1. Anthony AC
    Anthony AC Extra
    Dec 17, 2002
    17
    OK, I'm a newbie so go easy.
    Planning my DIY sub, I find that below about 19 Hz the driver goes into excursion overdrive. Hence as is commonly recommended a HP filter at just above this point is a good idea. Can someone tell me if at a 4 ohm sub impedance and wanting a crossover at 20 Hz, why I cannot just install a 2000uF cap (2200 available) as a passive filter after the amp and before the driver. I know (after reading [​IMG]) that the driver will vary with impedance at different frequencies but at this low a figure won't it be pretty stable at the rated value? Can I just do this?
    Any advice would be appreciated. Thanks, Anthony.
  2. Isaac C
    Isaac C Stunt Coordinator
    Aug 1, 2000
    140
  3. Dave Milne
    Dave Milne Supporting Actor
    Jul 2, 2001
    568
    Assuming for a moment that the cap would work (which it won't, as Isaac demonstrated)... Rod's rumble filter will give you 36db/oct rolloff (instead of 6) and cost less than a 2200uF, 100V, non-polar capacitor (if you can even buy such a thing). Electrolytics are polarized and unacceptable as pass elements in audio applications.
