Parts Express Dayton 12" DVC subwoofer
Discussion in 'Archived Threads 2001-2004' started by Max Payne, Jul 6, 2001.
  1. Max Payne
    Max Payne Agent
    Jun 29, 2001
    33
    What is the smallest size of enclosure you can build for a ported dayton DVC 12" subwoofer ?
    Thanks for any help
  2. James W. Johnson
    James W. Johnson Screenwriter
    May 26, 2001
    1,055
    You can build as small of an enclosure as you like, the question is what sort of performance do you want?....If you are looking for high spls in the deep bass region then you will need a fairly large enclosure of 5-7 cuft., if you are only concerned with high spls from 35Hz on up or something like that then you could build a box anywhere from 2.5-4cuft.
    James' DIY speakers
  3. Julian Data
    Julian Data Second Unit
    Oct 5, 1999
    408
    James,
    There's a limit on one can too small and too big. [​IMG]
    I like your recommendations though.
  4. Chris Sherman
    Chris Sherman Second Unit
    Nov 30, 1998
    378
    Parts Express gives 2.598 cu.ft. as the optimal size for a ported box for that driver. I put one in a 2.178 cu.ft. box tuned to 24hz. and am very happy with it, I wouldn't suggest going any smaller than that though.
