DorianBryant
- Apr 14, 2004
these come shipped in their original packaging. Amp has never been mounted. subwoofer was mounted but not used but a few hours.
Dayton RSS315HF-8 12" Reference HF Subwoofer 8 Ohm
New Feature On Parts-Express.com
(Be the first to rate this product)
Part Number 295-444
List Price: $179.99 EA
Price: $129.80 EA (1-3)
Quantity Price: $122.60 EA (4 + )
Quantity:
Need a large quantity?
In Stock? Yes
Weight: 25.00 lbs.
Email This Page To A Friend!
The Dayton Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
Specifications: *Power handling: 400 watts RMS/700 watts max *VCdia: 2-1/2" *Le: 1.71 mH *Impedance: 8 ohms *Re: 6.9 ohms *Frequency range: 25 - 1,000 Hz *Fs: 25 Hz *Magnet weight: 150 oz. *SPL: 86 dB 2.83 V/1m *Vas: 2.75 cu. ft. *Qms: 3.12 *Qes: .58 *Qts: .49 *Xmax: 12.3 mm *Dimensions: A: 12-3/8", B: 11-1/8", C: 5-3/8".
Extensively vented motor eliminates compression and allows quiet excursion
Lightweight black anodized aluminum cone for rigidity and lower moving mass
Triple shorting ring motor for ultra-low distortion
2-layer coil for reduced back EMF
Suitable for sealed or vented enclosures
Highest quality materials throughout for long-lasting performance
Dayton SA240 240W Subwoofer Amplifier
(Based on 15 reviews)
Part Number 300-804
List Price: $199.99 EA
Price: $128.88 EA (1-3)
Quantity Price: $118.50 EA (4 + )
Quantity:
In Stock? Yes
Weight: 12.90 lbs.
Catalog Page: 142 (PDF)
A new animal is prowling the subwoofer amp jungle! Behind the less than 10" x 10" faceplate lurks a tiger of a 240 watt amp, ready to unleash its power on your subwoofer driver. Includes all the features that you have requested, like a choice of RCA line level or banana jack speaker level inputs and outputs, automatic turn-on that is triggered by an input signal, and a phase reverse switch to match the subwoofer to your room and your other speakers. A single amp can accept a stereo input signal and combine it into mono, which is optimum for sub bass reproduction. The internal low pass crossover is fully adjustable between 40 and 180 Hz, and of course the amp has built-in protection against internal and external faults. Unleash the beast!
High power/low distortion
Adjustable low pass crossover
High and low level inputs/outputs
Auto On/Off
Phase reversal switch
Power output: 170 watts RMS @ 8 ohms 240 watts RMS @ 4 ohms
S/N ratio: 90 dB (A-weighted)
Dimensions: 9-13/16" W x 9-13/16" H x 5" D
Price is $175
Part Number 295-444
Quantity:
In Stock? Yes
Weight: 25.00 lbs.
Part Number 300-804
Quantity:
In Stock? Yes
Weight: 12.90 lbs.
Auto On/Off
Price is $175
