Parasound HCA 855A opinions
Discussion in 'Archived Threads 2001-2004' started by Eduardo Martinez, Dec 5, 2001.
  1. Eduardo Martinez
    Jun 28, 1999
    18
    I am looking for a way to improve the sound of my system. I have a Denon AVR 3300 receiver and Paradigm speakers (Mini Monitor, CC-350 and Atom). Also I have a SVS 25-31CS. Will I hear a difference (improvement) if I use it as a pre-pro and add Parasound HCA 855A? The Denon is rated at 105 wpc and the Parasound at 85 wpc. Anyone has this combination?
    Eduardo
  2. Eduardo Martinez
    Jun 28, 1999
    18
    Come on , guys! I know that you can help me.
    Eduardo
  3. Zbigniew
    Zbigniew Stunt Coordinator
    Jan 8, 2000
    185
    Eduardo,
    I have Denon-3300. I was using it by itself and with bigger brother of Parasound 855 - with 1500A, rated at 207 per channel/ Speakers in my case were Monitor 9, trying to fill a huge space.
    IMHO, you won't get as much from this upgrade as you would like. Minis are nice, fast and small speakers - and since you do have a very good sub, most likely you are running speakers as small. Then your Denon is not straining - it is happily churming along.
    If you want to hear the difference, put your money away, and either look at Studio 20/40 + matching speakers; then you will need external amps for it - or look into room treatment, and tuning together whole setup. This will give you more fun and improvement than Parasound.
    BTW - I do have a Parasound, and consider picking a used 2205 just to have it handy if I will start moving things around. They made great amps - but your Denon is very good, and in your setup I would suspect that after you take care of room, positioning, equalization, upgrading speakers would be best.
    Enjoy,
    _zjt
  4. Eduardo Martinez
    Jun 28, 1999
    18
    Zbigniew:
    Thanks for your response. Now I agree with you. Better speakers can produce better sound in this particular case than better amplification.
    Anyone has another point of view?
    Eduardo
  5. RobertW
    RobertW Supporting Actor
    Feb 27, 2000
    719
    i too, am using a parasound 1500a with my paradigm studio 20 speakers and denon 3300 as pre-pro. that's all i have at the moment, as i will be adding to the system in the future.
    while denon and parasound sound sonically alike, warmer and smooth, i found that adding the amp allowed the sound to open up, breathe, greater separation between voices, and instruments, and a cleaner, more detailed sound throughout. now, how much of this was a result of the extra power reserves of the 1500, or just the quality of the amp in general, i can't say.
    the 1500 is built a bit better than the 855, being a john curl design, and using his blend of jfets and mosfets. the 855, while adhering to the same basic design, does take a few shortcuts in parts used. but i've heard an 855, and i believe it sounds pretty close to the higher end parasound stuff.
    i'd say take a shot with it. or, if you're a music first guy, try the hca 1000a, or if you can find one, a 1500, to use in stereo, and let the denon power the rest. i think you'll see enough of an improvement in clarity alone to be pleased. although upgrading to the reference studio line of speakers is also a great way to go. AND THEN go for the big power amp.
    parasound and paradigms work really well together.
