Dan Baxter
- Dec 11, 2001
My Parasound amp seems to have a intermittent problem when powering up. Most of the time when turned on the amp will just read AC-line and never go into standby and turn on. Other times it works fine. Also I've noticed that sometimes when powered off there is a faint sizzling noise coming from the amp for a few seconds. It almost seems like the power switch dosn't always work. However, if I keep the amp off for about 10-15 min's it will always power up with the first flick of the switch. I've been told that it might only be a $5.00 switch problem. Has anyone else ever had power on problems with any Parasound amps?
Dan
Dan
