rodneyH
- May 22, 2001
This unit is approx 1.5 years old, in great shape, NO scratches on the face plate (black), includes programmable remote (same remote as used with the $3500 Parasound AVC2500u). 5.1 inputs for DVD-a/multi channel SACD, 5.1 DTS, 5.1 Dolby Digital, Dolby Pro-Logic decoding and Lucas-films Cinema Re-EQ, and also includes a Tuner. Great sound and picture, if you are looking for a decent priced pre-amp/processor this is the UNIT. Perfect working condition. I am selling because I just got a Rotel RSP-1066, but for the money this Parasound can't be beat. includes owners manual, remote and will be packaged well. Originally a $1200 unit. Will sell for $499 INCLUDING SHIPPING (Firm). This is the last try before going to ebay. It s the latest edition and has the very latest version of software.
E-MAIL me with any questions or information you might need. If you want pics, I can e-mail them to you.
Features
Specifications
•24-bit Burr Brown PCM 1716 D-A converters 24-bit processing
•Dolby Digital, DTS, LucasFilm Cinema Re-EQ, and Dolby Pro Logic
•Automatically Detects Dolby Digital 5.1 or DTS 5.1 flag
•Four Audio/Video Inputs with Composite and S-Video Connectors
•Three Separate Audio Inputs plus tuner
•Two Coaxial and two optical digital inputs
•Surround modes and digital inputs are assignable to inputs
•5.1 channel analog input for forward compatibility
•On-screen display, switchable for NTSC or PAL regions
•High quality FM/AM stereo tuner with 29 presets and preset scan
•Stereo bass and treble controls with bypass
•Remote zone audio with separate 12 Volt DC triggers
•External IR inputs, separate for main and remote zones
•Backlit Universal learning remote control
•High current encapsulated toroid power transformer
•FR4 glass epoxy mil-spec circuit boards
•Gold plated RCA jacks
•Removable IEC AC cord
•Fequency Response
Front (Large) 10 Hz-20 kHz Front (Small) 80 Hz-20 kHz
Rear (Large) 10 Hz-20 kHz Rear (Small) 80 Hz-20 kHz
Center (Large ) 10 Hz-22 kHz Center (Small ) 80 Hz-22 kHz
Subwoofer (LPF) 10 Hz-80 Hz Subwoofer (300 Hz) 10 Hz-300 Hz
•Harmonic Distortion
0.008 % Rear < 0.008 % Subwoofer < 0.008 %
•Input Impedance
Analog Inputs 10 kW, Coaxial Digital Inputs 75
•IM Distortion
(1 kHz 1V Output) All Channels < 0.06 %
•Weight 15 lbs.
•Dimensions 17 1/8" wide x 4 1/2" high x 13" deep 5 7/8"
•Power Requirements 110 V - 120 V 60 Hz AC, 60 W
220 V - 240 V 50 Hz AC, 60 W
•Signal/Noise Ratio (Flat/A-Weighted)
Front 90 dB / 93 dB
Center 90 dB / 93 dB
Rear 75 dB / 82 dB
Subwoofer 85 dB / 93 dB
•Tuner Range FM: 87.5 MHz to 108 MHz AM:520 kHz to 1610 kHz
picture here, NOTE-this is not my actual unit http://www.customaudioandvideo.com/h...ara1800lg.html
Features
Specifications
•Fequency Response
•Input Impedance
•IM Distortion
•Weight 15 lbs.
Front 90 dB / 93 dB
Rear 75 dB / 82 dB
