Parasound Amp(s) and Monitor Audio Gold Reference Speakers - Good Combination?
Discussion in 'Archived Threads 2001-2004' started by Scott-C, Feb 13, 2002.
  1. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    Would anyone comment on how they feel the Parasound amps (such as the HCA-2205AT and HCA-1500A) would do if combined with Monitor Audio Gold Reference speakers? I'm looking to get a sense of the sonic signature that the two would generate. Yes, I know that will also depend on room acoustics, other components, etc, but holding everything else constant, what kind of sound would this combo produce (i.e. warm, bright, neutral, laid-back, etc.).
    I would be adding a pre/pro to the mix as well - probably the Outlaw 950, and moving to a 7.1 channel setup.
    Thanks!
  2. Mal P
    Mal P Stunt Coordinator
    Mar 17, 2000
    127
    Hi Scott,
    The Monitor Audio GRs tend to be a tad bright (or should I say, clinical), so a generally warm amp should mate with them well. Parasound are considered to be a warm amplifier as I recall, but also try out Musical Fidelity.
    Cheers,
    Mal
