Darrin_R
- Nov 4, 2001
Can someone recommend a parametric equalizer for my subs. I have a couple of nasty peeks that i need to tame.
I guess to obtain a fuller and more complete EQ it would be useful to insert the BFD between the receiver and a crossover? For instance, if I mearly insert the BFD between my receiver and my subwoofer, I am only EQ'ing the subwoofer.
You can’t EQ both the L/R mains and the sub (assuming you’re using a powered sub driven from the receiver’s “Sub Out” jack). You will have to choose one or the other.
Doug is right. You don’t want to use the BFD on the mains because of its low-end A/D – D/A converters.
Wayne A. Pflughaupt
