Sansui 2000X
Grip
- May 18, 2008
- Paul
Hi I have two sub woofer questions, the first is I have two Paradgim PS-1200 subs around 10 yrs old, maybe a little older, and my prossessor is a Sunfire TGP-5. The TGP-5 has inputs for three subs, sub-1, sub-2, and sub-3, so would it be best to run the wires out of my sub's right, and left low level input, and use a "Y" connector on them, and then run them into one of the TGP-5's sub inputs? Or would I be better off to go from my sub's right, and left hi pass output, "Y" them off, and go to one of the TGP-5's sub input's? Also I noticed that one of my subs is makeing a wierd noise, when I took the sub apart I found the the speaker is shot, it's coming apart where the cone meets the frame, the fix looks easy enough, just remove the old speaker, and instal the new one, if Paradigm still has them, I plan on calling them tomorrow. Or would it be better to just replace the sub with a new one? Any info will be greatly appriciated.
Paul
Paul
