Paradigm Studio 60 manual (1 Viewer)
Swami
I was wondering if some kind soul could fax/mail me a copy of the manual. I bought a couple of used 60s which came without a manual. I feel kinda naked without it.
Please PM me for a fax number.
Swami
Swami
Anyone?
Much appreciated. On another note, what kind of spades do you use to connect the speakers. The binding posts seem to be 3/8 rather than the more common 1/4
Swami
Brian OK
Swami,
--- this is for the "other note" (can't help with the manual, but they are all generic when it comes to the Studio series. I will fax you my 40 series manual if you strike out with a call for the 60's manual)
Anyway,
The binding posts on the Studio Reference Series are 3/8".
I have a pair of new Studio 40's and my Analysis Plus 5/16" T-1 spades fit real snug and tight (they popped in for a real nice firm fit) which was rather odd. But, then again, the Paradigm rep told me not to file the spades until I tried them. He said "they should fit real tight, but should fit". Odd, I thought. But he was right. No filing.
My Studio CC, on the other hand, would not take kindly to the T-1 spades, and I had to file a small bit away to get them to fit. Rather odd, but my experience.
Good Luck,
BOK
John Garcia
NorCal
Call Bay Area Audio on DeAnza Blvd, in San Jose/Saratoga. They might have one laying around.
samtbax
