Blaine P
- Feb 11, 2004
I have decided to go with the following HT setup which fit my home decor (thus smaller fronts) and budget (same):
1. Paradigm Atoms fronts
2. Paradigm CC-170 center
3. Paradigm PDR-8 sub (will likely upgrade to PDR-10 next year with the 100% credit offered).
4. Paradigm CS-50R in-ceiling surrounds (3 total) (yes, I know, in-ceiling is not ideal, but is a requirement unfortunately).
Total Price: $855
My questions:
1. What receiver (under $500) matches best with this setup? (thinking either yamaha or panasonic xt45)
2. The Atoms recommended amp range is up to 80 watts with max input power at 50 watts. Is 100 watt per channel too much or causing trouble?
3. Does this price seem right or too high?
Thanks again.
Total Price: $855
My questions:
Thanks again.
