GrahamJW
- Sep 15, 2003
Hi:
I recently replaced my Paradigm PDR 10 with a Paradigm PW 2200 version 2 (YEA, I KNOW....IT'S NOT AN SVS). I noticed, compared to the PDR 10, on the back of the PW 2200 there are some more settings and inputs and output options. The PDR 10 had a subwoofer level control and a subwoofer output frequency which I have a pretty good idea on what these dials do. The other dial is a sub/sat phase alignment control. My question is what does this do? I have played around with it, but, to me, I don’t notice any change.
I have the PW 2200 hooked up with an RCA cable running from the sub out on the receiver to the Low Level input on the sub (does the phase control have any effect when the sub is hooked up this way?). There are actually 2 RCA plugs (marked Right and Left) for the low level input; the Right is marked LFE-in/sub-in. I read somewhere you can use a Y adapter to use both RCA inputs on the plug; is this a good suggestion?
Sorry for the multiple questions, but I have one more. There are 2 RCA (left/right) outputs that are marked High Pass Output. What are these outputs used for? I also noticed that on the previous PW2200 version there were speaker level inputs/outputs. This new version does not have those inputs/outputs. Do the High Pass Output RCA jacks replace the speaker level inputs/outputs?
The receiver I am using is about 3 years old; a Sony STR-DE835, and the bass management is limited to setting the speakers to large and small. I have the mains set to large and the rest set to small (my mains and rears are identical and can extend down to 45 Hz). I was debating whether to set them all to small. There is no place to set the cross over frequency on this receiver. Anyway, any comments would be appreciated.
Cheers..John
Cheers..John
