Paradigm or PSB with Denon ?
Discussion in 'Archived Threads 2001-2004' started by Al Moodie, Jan 29, 2002.
  1. Al Moodie
    Al Moodie Extra
    Aug 17, 2001
    22
    Hi everyone,
    ‘Have been lurking on and off in this forum since last August and
    after all that reading and some demo listening, I will probably decide
    on one of the following but need your comments pro and con:
    My room is 19 x 15 with 8 foot ceiling. 2300 cube.
    Regular size door opening (no door) on right wall.
    Viewing will be across the 15 foot width and 13 feet from
    the TV screen and front speakers.
    TV is a Sony KP53HS20 RPTV in a 6 foot wide recess with
    the screen level with front wall. Rear wall has 12 foot by 7.6 foot
    windows in center and when facing the TV the seating area (two
    recliners) is offset to the left 12 feet of the rear wall and the TV
    more or less centered opposite the seating area.
    Cannot mount surround speakers behind seating area unless against ceiling,
    so considering Dipoles, one on left wall 6 feet up and 5 feet from left seat
    and the other at same height but on top of a bookcase 7 feet from right seat.
    Budget is somewhat important and with the Denon 1802 I’m looking at
    the following speaker set-ups: (I believe the prices shown are MSRP):
    PSB: Image Series
    #1: 2 / 2B $400 Pr 2 / 1B $300 Pr 1 / 8C $300 Total: $1000.
    #2: 2 / 3LR $500 Pr 1 / 8C $300 2 / 10S $750 Pr (Dipoles) Total: $1550
    3 4 / 3LR $1000 1 / 8C $300 Total: $1300.
    Paradigm:Monitor Series.
    #1 2 / Monitor 5s $520 Pr 2 / Titan $220 Pr 1 / C370 $330
    #2 2 / Monitor 5s $520 Pr 2 / ADP170 $400 Pr (Dipoles) 1 / C370 $330
    Total: $1250
    Also considering a Rava or Paradigm PDR10 subwoofer or would this not be
    needed with any of these configurations ?
    I have heard / demo’d some of the above speakers but haven’t been able to
    hear all or do comparable A/Bs.
    Would appreciate any comments particularly from PSB and Paradigm owners
    re the above, Dollar Value, Sound. and room .
    Thanks, Regards.
  2. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    I haven't heard all of the setups you've listed but you really can't go too wrong with either. The only thing I would say is don't get the lower end subs from Paradigm. They aren't that good. You would be better off getting a Rava at that price point or a Hsu VTF-2.
    Patrick
  3. Trey Jones
    Trey Jones Stunt Coordinator
    Jun 16, 2001
    121
    In the setups you mentioned, I would go with the paradigms with the ADP's. Those would be better than the psb's as they go a bit lower, and sound fuller at higher volumes.
    Also do not go with that low end paradigm sub. Aim for a HSU VTF-2 or an Adire Audio Rava.
