Torsten Zurek
- Jan 18, 2003
Hi everybody,
i just started out to build my new system and ended up buying a HK Sig2.0 pre and aSig 2.1 pwr amp.Now im looking for new speakers. My preference is in Hometheater and about 30% into music.I listen to Rock and everykind of music except for jazz and classic(shame on me) . My current listening room is about 5m x 8m and the ceiling is about 3m high. the walls on the side have a lot of big openings.However i will be moving in about 2 years and my room will be about 5m x 6m with solid sidewalls and about 2.3m ceiling height. im willing to spend about 4000 max on a speaker sytem not including the sub.The sub will be added later for cost reasons.I looked into a lot of stuff and i eventually came up with 2 different systems;
B&W 804's or cdm9nt as front, center, 805's as surround(all used)
or
Paradigm studio100v2 as front, studio/cc, studio20's as surround.( new)
The reviews of the paradigm are really good but the only issue is , that a lot of people say that they need a lot of power. Since the HK Sig 2.1 has "only 100W RMS" im not quite sure if they can drive the paradigm.
What is the general opinion on paradigms . are they good speakers which live up to the level of B&W .Can my amp drive them and is the cost factor a valid reason?
I can not audition both of the systems without a significant drive and the only dealer around has paradigm studio 60 in stock where i could take my system and check it out.But will that be enough?
im gratefull for any advice.
TIA
Torsten
or
TIA
Torsten
