GregoriusM
- Jul 31, 2000
Hi!
I recently moved from a Denon 3300 with Titan mains, CDP-170 center and ADP-170 surrounds to a Denon 2805 and changed out the Titans with a new pair of Monitor 5's.
The Denon 2805 was all I was willing to pay for at the time (two weeks ago). I found the sound not very musical, and found the highs harsh, bright and a great deal of "sibilance", if I'm using that term correctly, where the S's mostly and the T's "ssssssssssstand" out extremely and make the music or HT or TV hard to listen to.
So, I did a long listening session with the Monitor 5's at my dealer, and compared the Denon 2805, and Denon 3805, and Rotel RSX-1056 (which is known for its musical qualities as a receiver) and found the 1056 to be better with music than the 3805, especially for the imaging, especially the depth. I didn't listen to HT, since I'm not as critical when listening to HT, even though I do about 60% HT and 40% music. (Obviously I decided I needed to pay more for the receiver).
Does anyone with experience with the Paradigm Monitor series, especially the Mini's, 5's or 7's, have the bright, somewhat harsh, "sibilant" sound with them?
If so, did that go away with "break-in"?
I have had the Rotel and Monitor 5's for 2 1/2 weeks, and have put at least 60 hours of time on the speakers. I have them crossed over at 40 Hz with a Paradigm PDR-10 subwoofer. (The Rotel allows different crossover points for the fronts, centers and surrounds.
Do you have any suggestions?
Also, for those with Monitor 7's, why did you pick the 7's over the 5's, if you don't mind me asking.
Thanks!
Greg
Thanks!
Greg
