Paradigm cinema 70 wattage
Discussion in 'Speakers & Subwoofers' started by Dale B, Oct 5, 2005.
  1. Dale B
    Dale B Stunt Coordinator
    Oct 5, 1999
    55
    Hello all. I just purchased 5 cinema 70 speakers from Paradigm. After I hooked them up I read where they are only 40 watts max. power input. I am powering them with an Onkyo 502 receiver. Should I be concerned about this 40 watt max? Most small speakers are rated at least 100 watts. Thanks. By the way, they sound really good.
  2. John Garcia
    Jun 24, 1999
    11,571
    25
    NorCal
    Nothing to worry about. With them set to small and without cranking it to the point that you hear distortion, they should be fine.
  3. Dale B
    Oct 5, 1999
    55
    Thanks John. I don't listen very loud at all.
