Paradigm CC 370 or Energy CC 3 for Center Channel?
Discussion in 'Speakers & Subwoofers' started by DeanRocks, Sep 29, 2005.
  1. DeanRocks
    DeanRocks Extra
    Sep 13, 2005
    18
    Both are in the $300 range and I'll be replacing my fronts within the next few months based on my center. If I get the CC 370 I'll get Paradigm fronts, If I go with the Energy I'll get Energy fronts. Just need a center now as I don't have one. ANy suggestions would be appreciated. Thanks!
  2. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
    Both are very similar. Only you can decide which you like better. You should also listen to the fronts you plan on getting and make your decision based on all 3, even though you are only buying the center now.
