Tom_Mack
- Dec 11, 2000
I have owned a paradigm monitor speaker system for about 1/2 a year now (Yamaha v596). Recently I made some changes that required me to re-calibrate my speakers. I have never been happy with the upper bass range (80-105hz) just above the crossover and have been trying some different things to see if I could get the bass any better. Just top see how it would sound I had set the center speaker to the LARGE setting. I did the calibration with AVIA at 75 db. The center speaker made some crackling noises at around 70db and I turned down the volume. I set the center to small and turned the volume back to 75db and it crackled once in 20 seconds. Is the noise I am hearing clipping? Isn't 70db a little low for having this happen even in large mode? Could there be a problem with the speaker that is causing this and could it also be the problem that makes the upper bass problems? Please give me some help if you can!!!
Thanks, Tom
Thanks, Tom
