Paradigm ADP170's or Mini Monitors
Discussion in 'Archived Threads 2001-2004' started by Ken Custodio, Feb 25, 2002.
  1. Ken Custodio
    Ken Custodio Second Unit
    Dec 5, 2001
    316
    Which would you get for rear surrounds. Paradigm ADP170's or Mini Monitors?
    K e n
  2. EricHaas
    EricHaas Supporting Actor
    Dec 25, 2001
    667
    There are strong differences of opinion on this. Mini-monitors are higher quality speakers, but the adp-170's are dipoles, meaning there are 2 sets of drivers. The adp-370's as I understand it are 2 sets of mini-monitor drivers and cross-overs in one enclosure. Not sure, but it's possible the 170's are 2 sets of Titan drivers. Personally, I prefer the sound of dipoles and would take the 170's. But you are going to have to demo it yourself.
  3. BrianWoerndle
    BrianWoerndle Supporting Actor
    Feb 19, 2002
    794
  4. Thad_C
    Thad_C Agent
    Feb 20, 2002
    38
    I have the exact same dilemma. I'm getting the Monitor 7's, cc-370 up front. I tested the mini-monitor surrounds with a PDR-12 sub and found the surrounds to be quite good. I hope to test the ADP-170's as surrounds this weekend. Can someone explain how the dipoles need to be set up? I do not have a solid adjoining wall for the left rear speaker, and I am wondering if this will make a significant difference.
  5. BrianWoerndle
    Feb 19, 2002
    794
    Dipoles need to be set up on the side walls, even with the listener, about 3 feet above ear level, and idealy several feet away from the back wall. The speakers use the side and back wall to bounce the sound back to the listening area giving a more difuse sound.
    If you do not have a side you you can still use the if you can suspend it, but you might get a lopsided sound because the side with the wall will have more emphsis.
    I would get the Mini Monitors for the rears and spend the extra money on the PS-1000 sub. That is my personal preference. But listen to them and see what you think.
  6. Steve Vinson
    Steve Vinson Auditioning
    Mar 1, 2002
    12
    I have Mini-monitors for rears, and they sound great. But, I've never heard any of Paradigms dipoles in my room . . .
    Steve Vinson
  7. Dave Schofield
    Dave Schofield Second Unit
    Sep 30, 1999
    401
    Those who have Mini-Monitors, how much did you pay for the pair? I think I'm going to buy a pair for use as my surrounds very soon and I need some ammo when I bargain with my dealer. He gave me a set of Monitor 3's a few years back for $100 off posted price...
    Thanks!
  8. Mike_A
    Mike_A Stunt Coordinator
    Oct 7, 2001
    153
    just wanted to point out that the monitor line (mini's & adp370) and performance line (titan & adp170) have more different than just the tweeter. the mid/bass driver is also different, as is the cabinet/crossover quality i believe.
    that said, i'd choose the adp170's if you mainly watch movies because i like dipoles too for that scenario. the timbre matching front to rear isn't that important, at least not nearly as important as matching the front sound stage properly.
  9. Alexis
    Alexis Stunt Coordinator
    Feb 18, 2002
    94
    the mini monitor and titan woofers are different, the mini monitors have a clear surface, the titans do not.
  10. Dave Schofield
    Sep 30, 1999
    401
    Is there any disadvantage to the shielded Mini-Monitors compared to the regular ones? I might use a pair in the future as my L/R's and it might be nice to have the flexibility to use them close to the TV...
  11. Ed_A
    Ed_A Stunt Coordinator
    Jun 19, 2001
    95
    Dave,
    One disadvantage; the shielded ones cost a little bit more. If you were going to be using them butting up against your TV then you'll want to go with the shielded ones...or if you'll be using one as a center channel placed right on top of or below your TV.
    Otherwise the standard ones work fine. I have the Mini's set up as the main speakers, (unshielded) placed about 2 feet from my TV and haven't had any interferance problems.
    HTH,
    Ed
  12. Dan Da Silva
    Dan Da Silva Stunt Coordinator
    Feb 14, 2001
    71
    I got my pair of Mini Monitors for $269 from AVI Electronics in NJ.
