Javier_A
- Dec 10, 2002
Hi,
I just purchased a set of Paradigm speakers:
fronts: monitor 7
center: CC-370
surrounds: ADP-370
sub: PDR-12
This will be set up in my living room, which is about 13x13, with a wall and window on the left side, and no wall on the right side of the room. As you can see, I have no way to mount the speakers to the sides of the couch, which is against the back wall of the room. Is it ok to mount the ADP-370s, or any dipole speaker, against the back wall? I just want to make sure that I don't lose the "benefits" or "effects" of these dipole speakers by being on the back wall. How about some speaker stand maybe, would that work better? Otherwise, I guess I could trade them for mini-monitors if you think it would work better for my setup.
Thanks!
fronts: monitor 7
center: CC-370
surrounds: ADP-370
sub: PDR-12
Thanks!
