AngeloEug
- Mar 11, 2005
I've been considering the 3se's to replace my front LCR channels for my listening and HT. Currently, my LCR's are all tidily tucked inside my Media Niche.
To replace the LCR speakers, I would have to alleviate my center speaker and place them horizontally on top of my Mits 55" rear proj.
Visually this would look fine however I'm worried that the 3se's aren't magnetically shielded and may affect picture quality and will imaging suffer from this type of speaker placement. I have read some threads where some are running without a center to accomodate better fronts and running "phantom". I'm sure my pio 1014 can be set-up this way.
I can't have them on the floor or on stands due to "little fingers" in the house.
50% ht and 50% music...worth the sacrifice of the center channel for a "size" upgade from Athena Micra6's?
Please help...I may be able to get into the Paradigms for under $100/pair.
Thanks in advance!
Angelo
Thanks in advance!
Angelo
