Panny47 remote control codes???
Discussion in 'Archived Threads 2001-2004' started by JoeyT, Sep 18, 2002.
  1. JoeyT
    JoeyT Stunt Coordinator
    Jun 7, 2002
    98
    I have found the owners manual, long-short service manuals on the web, but have not had any dice with the remote control manual which they conveniently placed in another manual that I do not own.
    I desperately need to program my remote that came with my TV. My wife is on a mission to remove clutter. Next think you know it will be may amps and speakers[​IMG]
    Thanks!
  2. Manuel Parrado
    Manuel Parrado Stunt Coordinator
    Jan 7, 2001
    119
    If you are talking about the new models (like 47wx42), then the codes are inside the tv's owners manual and there is no remote manual.
    If you are talking about last year's model(47wx49), then you can try and use the remote programming method for this year's model and see if it works.
    The bad thing is, I'm at work right now but can scan the page with the codes and send it to you tonight when I get home.
    Let me know if interested.
  3. JoeyT
    Jun 7, 2002
    98
    That would be great if you could e-mail me the page![​IMG]
  4. Manuel Parrado
    Jan 7, 2001
    119
    I will but you have to let me know what tv or remote you have.
    There are two different remotes for this year's models.
    Models with the protective screen have a bigger remote with a few additional functions.
    Both remotes have different codes so tell me which one you have and that way I don't have to scan pages you won't need
    Regards
  5. JoeyT
    Jun 7, 2002
    98
    Manuel,
    Thanks again. It is not this remote:
    http://www.avs-store.com/MSDetails.a...umber=PT47wx42
    While this one looks like a 4 in 1 remote, mine is a 8-9 in one remote. (Bigger). I tried to find a picture on the web but no dice.
    Just let me know if this is too much trouble.
    Thanks!
  6. Manuel Parrado
    Jan 7, 2001
    119
    Don't worry, I will send everything just in case.
