Panny RP91 - New Firmware?
Discussion in 'Archived Threads 2001-2004' started by Brajesh Upadhyay, Nov 27, 2001.
  1. Brajesh Upadhyay
    Brajesh Upadhyay Supporting Actor
    Jul 11, 1998
    787
    There's talk of a new firmware that supposedly fixes the left shift problem on progressive out for 16:9 displays. Anyone have this firmware here?
  2. Ron Reda
    Ron Reda Cinematographer
    Jul 27, 2001
    2,276
    2
    110
    Brajesh,
    I just received my new RP91 yesterday and the back of the player says that it was manufactured in October 2001, so I'm thinking I've got the firmware upgrade. However, I will check it out this weekend when I've had time to mess around with the player.
    Ron
  3. Scott-C
    Scott-C Supporting Actor
    Jul 23, 2001
    863
    Hmm, interesting. If you do have the firmware upgrade, please let us know. I'm considering replacing my DV-37 for one of these and would be very interested to know if they put out a firmware upgrade. Also, if there is an upgrade, does it fix any of the other known RP-91 bugs? (i.e. pink tint, etc.).
    Thanks!
  4. Jeremy West
    Jeremy West Auditioning
    Jan 23, 2001
    10
    I recently sold the Champagne RP91 I purchased earlier this year and bought a Black model. The build date on the new player is August 2001 and I immediately noticed that the image was centered correctly, no left shift problems. I also noticed that the back of the player was slightly different with certain input terminology missing above the TV inputs.
    JW
  5. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    To check firmware upgrade press stop, pause, open/close all at the same time on the front of the unit and then press the number 7 on the remote.
    The last three digits give you the firmware number.
    Patrick
  6. Geb Buxton
    Geb Buxton Auditioning
    Jun 30, 1997
    5
    Geb Buxton
    Obi,
    Is there any way you can talk to your contacts at Panasonic and see if you can get details on this firmware upgrade.
    The AVS thread mentions that the firmware can be upgraded by inserting a DVD with the new firmware on it. Boy would that be easy!
    Thanks!
    -- Geb --
  7. george kaplan
    george kaplan Executive Producer
    Mar 14, 2001
    13,063
    2
    But where do we get the disc. This disc is what I want for Xmas. [​IMG]
  8. Kevin N
    Kevin N Stunt Coordinator
    May 14, 2001
    82
    Jeremy, when you put it into auto and play a 4:3 disc, does the player still have the overscan problem on the right side of the image?
  9. Andy_S
    Andy_S Second Unit
    Jul 19, 2000
    393
  10. Michael D. Bunting
    Michael D. Bunting Screenwriter
    Jun 9, 1999
    1,828
    Michael
    I think you can just burn it to a CD-R and put it in the RP91.
    See the AVS thread for more details.
    I have downloaded the file...but haven't tried it out yet.
  11. David Barteaux
    David Barteaux Stunt Coordinator
    Jan 6, 2001
    179
    I upgraded from firmware 50G188 to 50G227 no problems at all. I have the black RP-91 manufactured in May 2001.
    I used the DiscJuggler demo verson to burn the CD-R. Put the CD in the player and it asks if you want to update. Update took about 5 minutes.[​IMG]
  12. Jagan Seshadri
    Jagan Seshadri Supporting Actor
    Nov 5, 2001
    528
    Firmware Coaster #1 [​IMG]
    Ok, I downloaded that zip file, unzipped it (without any errors) to get the .nrg file, opened it in Nero which prompted me with a dialog box "Foreign image settings".
    After I shrugged and clicked the OK button, it said "The entered block size does not correspond to image length. The block size may be wrong. Do you want to correct the value or ignore the problem?"
    I opted for Nero to correct the value (again, shrugging). Then I proceeded to burn it, which took an astonishing 7 MINUTES (at 4x burning speed for a 22Mb file?!).
    RP-91 rejected the burned CD saying that "This disc cannot be played on this machine" or something like that.
    What gives?
    -JNS
  13. Robert George
    Robert George Screenwriter
    1,107
    101
    1,610
    I've started a new thread on this that will stay at the top of the hardware forum for several days. Anyone that has tips or info that others can use, please post it there.
