Glen W
- Dec 2, 2001
Howdy:
Just finished hooking up the Panasonic RP 56 to my Toshiba 50HX71. I have used component video cables to connnect. The RP 56 is set to 16:9. The RP 56 should think it is connected to a 16:9 display. Even though the TV is a 4:3 set I have been told that it has a 16:9 mode that is activated when it detects a 480p or 1080i at one of the component video inputs. The RP 56 is set to deliver a progressive scan output.
I have tested this setup with Star Wars Episode 1. I have noticed that the image looks like a cinema scope movie projected with a non-cinema scope lense. In other words the image fits on the screen fine from left to right. But the actors look taller and skinnier. When the RP 56 is to 4:3 letterbox mode the actors and other objects return to their normal preportions. Does anybody know if this is a defect in the RP 56 or the TV? Or possibly a mismatch between the two components?
Thanks Glen
Thanks Glen
