Panny pt47wx49 too much Red!
Discussion in 'Archived Threads 2001-2004' started by Rick Pay, Jun 16, 2002.
  1. Rick Pay
    Rick Pay Stunt Coordinator
    Apr 22, 2002
    62
    10
    Tv was fine all day and all of the sudden tonight there is this red tint to everything, including dvd's. Whenever there should be a black screen it has this red tint, like when you are changing the channels and the picture has a red tint on directv and dvd's. Did no tweaks and tv was fine all day until now. Any ideas? tv is 2 weeks old.
  2. Chris Perkins
    Chris Perkins Stunt Coordinator
    Apr 28, 2002
    52
    Sounds like the infamous "Evil Pop"! Go to www.panny.tv for the simple fix. It really is something you can do yourself.
    Good luck, and don't be too frustrated. It has been experienced and repaired by many a Panny owner.
    Chris
  3. Sean Moon
    Sean Moon Cinematographer
    Jan 25, 2001
    2,041
    The evil panny pop. Happened to mine about three weeks ago. It is an easy fix. Go to www.panny.tv for more info. You can fix it by going into the service menu. On the panny site it will tell you what settings do what.
    I had my set for about as long when my POP happened. I was pissed and moaned for a day until I read on how to fix it. TV looks better after tweaking it.
    Just disabled SVM last night too(damn are my fingers sore from doing that!) and the picture is now amazing.
  4. Matthew-K
    Matthew-K Stunt Coordinator
    May 24, 2002
    95
    Disabling the SVM on the panny. What exactly does this do for the tv? I would like to do this on my set and was just wondering what changes it will produce.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    It takes you a step closer to an edge enhancement-free viewing experience, Matthew. Scan-velocity modulation increases the scanning frequencies at the edges of onscreen objects in order to give the appearance of sharpness--but it is nothing more than a distortion. And the larger the screen, the more obvious its presence. It's almost always better to disable the SVM.
    Your Panny's going to be okay, as your fellow Panny owners have indicated.
  6. Sean Moon
    Jan 25, 2001
    2,041
    When I first got the set I had horrible halos on all edges, especially on the right side for some reason. After disabling the SVM, it was a huge difference in pic quality. A great tweak!
