Panny PT-47 and progressive scan dvd
Discussion in 'Archived Threads 2001-2004' started by tommy_esq, Aug 17, 2001.
  1. tommy_esq
    tommy_esq Stunt Coordinator
    May 11, 2001
    119
    not being impressed with my first generation sony dvd player's (w/svideo connect) image on this set i decided to give progressive scan a whirl before i made my decision to keep/return the TV.
    i picked up the JVC S65 from best buy for $249. after firing it up, i have to say the difference between 480i and 480p is HUGE! its almost as noticeable as vhs and dvd was on my 32" direct view set. i'm not sure if i will keep the JVC or get one of the Panny progressive players (maybe the RP56 for the same price when it is in stock) but progressive scan seems to be the only way to go on this set. i hope i will be as impressed with HDTV once i get a STB.
  2. Brian Mello
    Brian Mello Stunt Coordinator
    Mar 20, 2001
    125
    I can guarantee you will be more impressed with HD content. The only problem is once you start viewing HD material, the regular Satellite Channels look even worse. [​IMG]
