NeilO
- Aug 30, 2002
I have a Panasonic CT-27SF26. I've had it for more than 2 years. I just have been hooking things up with a Pioneer VSX-D811S receiver and speakers and such.
I hooked the "to audio amp" connections from the Panasonic to the Pioneer receiver TV/SAT analog audio input.
The Panasonic has three options:
1. Speakers On - TV speakers operate normally
2. Off and Variable Audio Output - TV speakers off - audio adjustable by TV
3. Off and Fixed Audio Output - TV speakers off - audio adjustable by the external amplifier.
The thing is that options 2 and 3 don't seem to be working as expected. Option 2 seems to send the audio to the receiver, but it also seems to be coming out of the TV speakers at the same time. The TV volume control does affect the level of audio going to the receiver. Option 3 does turn off the TV speakers, but mysteriously I can't adjust the volume with the receiver. It is a constant high level. Maybe there is some incompatability between the TV and receiver or there is something to adjust.
I presume that other Panasonic TVs have similar options and so even if you don't have this TV you might have a similar experience.
Thanks for any advice on this.
Neil
Neil
