Panasonic TU-HDS20 HDTV rcvr reset !?!?!
Discussion in 'Archived Threads 2001-2004' started by RickMel, Jul 25, 2002.
  1. RickMel
    RickMel Extra
    Jun 2, 2002
    22
    Not sure if this is the correct forum....
    I bought the TU-HDS20 HDTV rcvr about a week ago and other than it being very slow, seemed to work fine.
    I rcvd the 8.10 upgrade which has sped things up significantly but when I am deleting channels from "favorites" it turns itself off an resets occasionally. Is this normal ??? It isn't over heating and doesn't reset during normal surfing or viewing.
    What's going on? When it resets, I lose all the changes I've just made.
    Does anyone have any insights? Any have the same problem? Is this a tradeoff for speed with the new version?
    Also, I bought this as an open box at Tweeter for $350 which seemed like a deal... so, the question remains, is this normal or should I return it? They may not have another!
  2. DanHuff
    DanHuff Auditioning
    Mar 24, 2002
    7
    This is normal on the TU-HDS20 and is a known bug. When you try and add/delete channels to favorites, when you reach +/-100 channels the box will re-set. No cure yet, hopefully the s/w will be upgraded one more time to take care of it! Check out avsforum.com for more info......
