Panasonic TU-HDS20 for $325..good price?????
Discussion in 'Archived Threads 2001-2004' started by Jonathan Trueh, Aug 31, 2001.
  1. Jonathan Trueh
    Jul 11, 2000
    15
    I was the BGE HOME store in my area and I saw an advertisment for this model. Is this a good price? I'd really like to get some input ASAP. I don't know how long this price will last. I think it's a closeout but I'm not sure. I plan on getting the new Toshiba 50HX81 in October, so I'd like to pick up an HD tuner at a good price.
    Also, do I need a HD antenna as well? I live in a apartment climbing on the roof is not an option. Do they make HD antennas that can be used indoors.
    Sorry about all the questions but the idea of being able to experience HDTV in the next few months has got me drooling with delight.
    My System:
    Mains-PSB 6T
    Center-PSB 9C
    Surrounds-Rock Solids
    Sub-Klipsch KSW-15
    Receiver-Sony STR-DE825
    DVD Player-Sony DVP 550D
  2. CarlS
    CarlS Stunt Coordinator
    Aug 15, 2000
    83
    That is an excellent price for this unit. They usually go for over $700. You should make sure that it is not a reboxed unit.
    Depending on your location, you shouldn't need to mount a roof antenna. I would try a simple amplified antenna first.
