Panasonic TU-DST51 HDTV tuner
Discussion in 'Archived Threads 2001-2004' started by Steve G, Jan 19, 2002.
  1. Steve G
    Steve G Agent
    May 31, 1999
    41
    Recieve and Record Over-the-Air HDTV now when paired with a Panasonic D-VHS recorder. This is 1 of only 2 units I'm aware of that will let you do this.The other being a Panny DST50. These STB's are no longer made and will more than likely never be made again.
    Receives and decodes all ATSC formats.Built-in ATSC/NTSC tuner.When connected to your HDTV-compatible monitor this unit can display [HDTV]1080i or 720p or Standard DEF [SDTV]480p or 480i formats. Dolby Digital AC-3 out as well as many other features such as Apect Ratio control.
    Includes original Remote, manual and box.
    Asking $800. Will consider Panasonic tu-dst20 or Toshiba 3000 HDTV sattelite units or 6.1 receiver w/ DPL2 as partial trade.
    Thanks Steve
    email is [email protected]
  2. Steve G
    Steve G Agent
    May 31, 1999
    41
    TTT
    Bumping it up with a little more info.
    This unit also features a Digital Interface for high speed data transfer to Panasonic D-VHS recorders.
