Panasonic TH-58PZ850U Mounting Holes (1 Viewer)
Gilles Cyr
Hi Everyone
I am preparing a wall to mount my forthcoming Panasonic TH-58PZ850U.
The mounting holes pattern is 320 mm x 660 mm.
Can someone tell me what is the distance between the upper mounting holes and the top of the display.
Much appreciated.
Gilles Cyr
Hi everybody.
I had a second reply from Panasonic.
The metric measurement of 320 mm on the vertical plane is correct.
So is the horizontal separation of 660 mm.
The distance of the upper holes to the top is: 195 mm or 7.68 inches.
Regards
ChewyWaffles
