Keith Yatsuhashi
- Jun 30, 1997
I have a tech coming to fix this TV this week, but I thought I'd ask a couple of questions here to get some idea what's going on with it. Basically, according to the store where I bought it, there's a problem with the yoke (sp?). The picture is tilted slightly, with the lower left corner being lower than the right corner. You can really see this with subtitles, they slant up to the right. The TV in the store had the same problem. They said it was something Panasonic is aware of. Also, I plugged a Phillips 711 into the component 2 input, and got nothing. No image. The S-VHS works fine, as does the component 1. I can't figure that one out. I think it's either in the player or the cables, because I switched the input to component 1 (same cables) and still had no image. (but the onkyo I have hooked up to component 1 works fine). I returned the cable, but didn't get a replacement because I wasn't sure where the problem was.
