Panasonic Serivce Menu Help!
Discussion in 'Archived Threads 2001-2004' started by JeffreyH, Dec 30, 2001.
  1. JeffreyH
    JeffreyH Stunt Coordinator
    Sep 5, 2001
    80
    Ok, I got into the service menu for the Panasonic tv's and to the part when it reads "CHK" in the upper corner.
    Then I can get to the "self check menu" where it list things like sound-ok CRT-ok, Comb-ok etc.
    Then what?
    What can be adjusted?
    I hit the arrow keys and it just take me out of that menu.
    Thanks for any help.
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    With chk on screen ... hit the power button on remote.
    Obviously you enter at your own peril and if you wreck the set, take responsibility for that and pay for the repairs yourself.
    Regards
  3. JeffreyH
    Sep 5, 2001
    80
    Whoa! What can you screw up and what can you tweak on this menu? I'm having problems with the reds using component cables, can I make a difference here?
  4. Dwight Amato
    Dwight Amato Stunt Coordinator
    Nov 29, 1998
    193
    If you don't know what you are doing, then DO NOT go into the service menu. This is true of any brand set.
