Gus Valladares
- Aug 10, 2002
Hi!!!
I just bought my first HT, a Panasonic SC-HT95. I posted another message before, because I got a problem playing Mp3s. So, I can change it. I'm not sure if this HT is good enough.
I got a limited budget ($500-600) to buy a complete system in New York. So, I got the chance to change this Panasonic to another HT, or try a new machine (maybe mine has a problem with the MP3s).
PLEEEEEEEASE! I need your help!!!
1- The problem playing Mp3s (the sound jumps) is common with the HT? Should I burn a CD in a certain way?
2- What do you think about this HT? Is good enough?
3- I can change for another HT? Should I do it?
Please, I need your advice! I got a few days to change it! Help me because I'm new on this.
Thanks! Thank you very much!
Gustavo
Gustavo
