BrianWH
- Jan 13, 2004
I have an S97 connected over both component and HDMI to a JVC HD-ILA set, producing the same well-known and documented zoom artifacts when the S97 tries to zoom anything. Great player otherwise.
This doesn't bother everybody due to the ubiquity of "16:9 Enhanced" or "Anamorphic" widescreen DVDs on the market. But since I got my first HD set, I've found quite a few of my DVDs are "letterboxed" widescreens formatted for 4:3 sets. Most of these appear to have been released in that time period of DVD infancy between 1996 and 1998, with a few exceptions, as there were few 16:9 sets back then. However, a few of my Widescreen DVDs are doing something really odd with the S97...
With the S97 set to "Zoom = 16x9 Standard"...
The DVD image fills the TV, the S97 claims "Zoom = 1.00, 16x9 Standard", but the familiar S97 Zoom artifacts exist. The effect is easiest to see with white text on black backgrounds - produces a jagged ghosting double image effect. So it looks like the S97 Zoom is ON. If I tell the S97 that a "4:3 Letterbox" TV is connected (Setup Menu, NOT the Zoom) the S97 says "Zoom = 1.00, 4:3 Standard" and has NO artifacts.
The aspect control (or zoom) on my TV does a good job with no such artifacts, so I know its the player doing some kind of auto-zoom that can't be disabled. If I take an old "Letterboxed" DVD (with the black bars on all four sides, when on 16:9 set), and use the S97 to Zoom to fill my screen, it looks the same as one of these odd DVDs.
Has anyone else with an S97 and 16:9 set noticed this issue?
In short this type of DVD seems to tell the S97 to Zoom to fill the HD screen at 16:9, which it does with the artifacts, but the S97 reports "1.00 Zoom, 16:9 Standard". Very odd. A few titles that I have that have this issue:
The Truman Show
Event Horizon
Crimson Tide
Good Will Hunting
Great Expectations (1998)
Waking Ned Devine
A Bug's Life
Sorry for the length, but complex issue...
Brian
The Truman Show
Event Horizon
Crimson Tide
Good Will Hunting
Waking Ned Devine
A Bug's Life
Brian
