panasonic rp91 problems?
Discussion in 'Archived Threads 2001-2004' started by Ken Yeung, Nov 13, 2002.
  1. Ken Yeung
    Ken Yeung Auditioning
    Apr 26, 1999
    9
    hi all,
    i've owned the panasonic rp91 for 4-5 months now and i have had no problems. However just the other night, the progressive scan light seems to go out while playing, however if i pause the disc the light comes back on. I've also tried the other component input on my tv(tosh 50h81)
    any ideas?
    thanks!
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    There is a mode that when you are playing a DVD, the light goes out. Hit DISPLAY twice when a DVD is playing and the icon menu comes up. There will be one that says BIT and another to the right of it with a little light icon. There are three choices: Bright, Dim, and Auto.
    You have it in the Auto mode now, so the light will go out when a DVD is playing. Simply set it to one of the other choices and it will stay on all the time.
    DJ
