Panasonic RP82 Vs. Panasonic RP62 (1 Viewer)
John Stockton
Since finding an RP 82 is as easy as finding a virgin in a maternity ward, I was wondering if anyone knows if the picture quality from the 62 is the same as its bigger brother. I ask this because I heard that they both use the same chip, and the only major difference is that the 82 has DVD audio and the 62 has not.
TimothyE
I think you'll find that the RP-62 has CCS (Cross Color Suppression) turned on, resulting in the flicker bug.
John Stockton
Thanks for your reply.
I am not very familiar with the Flicker bug. Is it as bothersome as the Chroma Bug?
Can the CCS be turned off in the 62?
ZeppelinDude93
