Sanjay Gupta
- Jun 30, 1997
- Sanjay Gupta
I have a 32" 16:9 Television, with no component inputs and/or progressive support. I use S-Video to connect from the player to the television via the receiver (Denon AVR5800). Since Progressive is a non issue for me right now, my question is, how would you rate the Panasonic RP82 in terms of picture quality when using only the Interlaced S-Video output? What other players would you compare it with? I have in the past owned the Sony S7000 and the S7700, both of which I found to have a very satisfying (read great) picture. Also how would you rate the RP82 in terms of sound quality for DVD movies using the coaxial output and the audio CD sound quality using the optical output. By the way I use the coaxial output to connect to the receiver for DVD Movies/Music and I use the optical output to connect to the receiver for Audio CDs. This way I just switch the receiver to the CD input for Audio CDs and switch to the DVD input for DVDs, this allows me to have different settings (Surround paramaters, tonal settings etc.) for Audio CD and DVDs without having to change them each time. Please restrict your comments to Audio CD quality and Interlaced DVD output, although comments related to the DVD Audio quality will also be welcome.
Sanjay
Sanjay
