Panasonic PT900 grinding noise??? (1 Viewer)
kah68
My 900 has a grinding noise like the fan is rubbing on something inside, anyone else have this happen, what should I look for? The bulb has over 3000 hrs on it, would that make any difference?
brinnington
Bob Wilkins
Although I am not familiar with the Panasonic PT900, I would think that the source of the problem is the fan. Your bulb does not have any moving parts, so I can't see how that could cause the noise you mention.
Best,
Bob
newyork333
