chris_clem
- Mar 9, 2003
Hi!
I am very nearly about to pull the trigger on my first FP. After months of reading various posts here and scouring the web for articles and such, I have come to the conclusion that a Panasonic LCD would suit my needs. However, I am not sure whether I should get the PT-L200U or the PT-300U. I know that the main difference between the two lies on the resolution of their displays (with most of the other specs being the same except for a 100ansi lumens difference between the two) but is that worth the price difference? I will be using this almost exclusively for DVDs with conventional cable viewing perhaps a distant second (I am unsure how to connect basic cable to these projectors!). Living here in the Philippines, I will not be able to access any HD content as ther are no current plans for its required upgrades in broadcasting infrastructure.
I have only seen the 300U in action so far and I must say that I am amazed at its picture quality (the 200U was unavailable for demo as it was not in stock). I guess, my main questions is: "When watching DVDs would it look the same on both projectors since their resolutions both exceed that of DVDs?"
If anyone has had experience with both projectors please help me out.
Chris
Chris
