panasonic pt-ae100e help
Discussion in 'Displays' started by tirpas, Sep 20, 2003.
  1. tirpas
    tirpas Auditioning
    Sep 20, 2003
    I have problem with panasonic pj(pt- ae100e),its green and pink colors in the corners,seen only on grey scale.
  2. Rik P
    Rik P Stunt Coordinator
    Aug 25, 2001
    111
    I've read about this over at the AVS forum there has been some talk about LCD panel discoloration.
    They think this may be due to inadequate vetilation in the projector causing the panels to burn and discolor. Not sure if this is the same problem your having but you can take a look over the AVS forum and see.
  3. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    I have the same problem to a degree. I believe it has to do with the polarizer plate warping. I don't think it is necessarily the LCD panel itself. I noticed it happening in my projector and I have since made some adjustments to higher fan speed while the light remains on low. Make sure you use the medium or high fan speed and allow proper ventalation. To fix the problem, I think it might require replacing the polarizer plates.
