Panasonic E50 users
Discussion in 'Playback Devices' started by Rob Mac, Feb 4, 2004.
  1. Rob Mac
    Rob Mac Stunt Coordinator
    May 27, 2001
    129
    21
    Ontario, Canada.
    Rob
    The Panasonic E50 has an edit function where a commercial or unwanted segment can be erased on a DVD-r. Has anyone tried this function? After disc is finalized, does the program play skipping the erased bits seamlessly? Also, exactly how bad does a program recorded at 3-4 hour speeds look? If you were dubbing a laserdisc that was between 2 and 3 hours long, using Flex Record, at what length would you be pushing it quality wise?
  2. JeremySt
    JeremySt Screenwriter
    Aug 19, 2001
    1,771
    14
    610
    Jeremy
    AFAIK, you cannot edit DVD-R, only DVD-RAM.
    The picture quality dropps off noticably after 3 hours, at least to my eye.
  3. Scott Merryfield
    Dec 16, 1998
    12,406
    1,135
    9,110
    I believe the resolution on the Panasonic recorders drops noticably at around 2:20 using flexible record.
  4. Rob Mac
    May 27, 2001
    129
    21
    Ontario, Canada.
    Rob
    Thanks for the quality info. If a DVD-R can not be erased, why does my manual say DVD-R AND RAM can be erased fully or in segments and that only the DVD-RAM can be re-recorded on. The DVD-R recording space is lost when it is erased. Has anyone actually tried to erase part of a DVD-R? If you do, let me know how another dvd player plays over the erased bits. Note: DVD-R can only be erased BEFORE finalizing disc.
  5. Rob Bournemouth
    Rob Bournemouth Auditioning
    Jan 9, 2004
    2
    The E50 will only allow you to erase an entire recording on a DVD-R disc, you cannot edit parts of a recording out. See page 42 and 44 of the instruction manual.
