Panasonic DVD-RP82
Discussion in 'Playback Devices' started by Adam_mmm, Dec 2, 2003.
  1. Adam_mmm
    Adam_mmm Agent
    Oct 9, 2003
    44
    I have heard many good things about this dvd player and was curious if it has the best price/pc quality ratio. If that is the case i will definitely be purchasing it, however I was concerned it would not play dvd+r or dvd-r being that I back up numerous dvd's. please advise
  2. PaulT
    PaulT Supporting Actor
    Oct 28, 2002
    932
  3. Adam_mmm
    Adam_mmm Agent
    Oct 9, 2003
    44
    why did they discontinue it
  4. Don_Berg
    Don_Berg Supporting Actor
    May 30, 2003
    931
    The Panasonic RP82 and the same designed XP30,XP50 models play all types of DVD recordable (-R/-RW/+R/+RW) even VCD/SVCD on CDR/RW. Panasonic couldn't afford to make these high quality expensive models and compete against the new lower-quality/cheap models from China, so last year they discontinued all of their models and came out with new cheap models without the good Faroudja de-interlacer. You can buy the good old models on EBAY, I recently bought a used XP30 for $200 and it works great with low hours! There are no new models in the under $300 range that come anywhere close, so EBAY is one of the only sources now, but I'd recommend it.
  5. Steve_Cohen
    Steve_Cohen Stunt Coordinator
    Oct 29, 2002
    52
    As much as I like (or did like panasonic) as I own the 53wx42 and a panny vcr, in addition to the RP-82, my reccomendation would be to stay away. I have had the rp-82 for 8 months when it developed the "H02" error which many of the panasonic dvd players have this problem. Do a search on "H02" and you will see. While many will say that "I love panasonic and never had problems" the many different models of panny dvd players have this problem. I am currently fighting with panasonic to cover all costs of the repair. Wish me luck.
    Try pioneer or JVC IMHO.
