Panasonic DVD placment... On top of Onkyo 595? Ok? Bad?
Discussion in 'Archived Threads 2001-2004' started by Bill Johnston, Dec 17, 2001.
  1. Bill Johnston
    Bill Johnston Stunt Coordinator
    Nov 20, 2001
    77
    Ok... I set everything up yesterday... Now today i was looking through the manuals...
    Right now I have the 595 on the bottom... then the DVD... then a shelf... Then a Digital Cable Box... Then a Sharp VCR...
    The manual states NOT TO put the DVD on a Receiver due to the heat factor... Is this true?
    If so... would it be better to leave the onkyo on the bottom... put the cable box on top of that... then... the shelf... then the panasonic DVD and then the VCR?
    Will heat actually distroy the DVD Player?
    Thanks!!!
  2. Steve Daniels
    Steve Daniels Stunt Coordinator
    May 14, 2001
    144
  3. Sean Conklin
    Sean Conklin Screenwriter
    Oct 30, 2000
    1,720
    I would not put anything on top of or directly under my receiver, BAD IDEA.
    Try to keep all your components separate, and do not stack anything directly on top or bottom of anything.
  4. PatrickM
    PatrickM Screenwriter
    Aug 10, 2000
    1,138
    Time to get a new rack. You need proper spacing for all your components but especially the receiver. DVD players don't typically generate tons of heat but keep them spaced properly will ensure they last longer.
    Patrick
  5. John Morris
    John Morris Guest
    I've found that todays processor based components are like computers... heat makes them misbehave. I have an old Panasonic A310. If I put it on top of my hot RePlay Tv unit it starts to lock up. Once it cools down, all is well. IMO, any unit which uses some processors can misperform if they get too hot...
  6. Bill Johnston
    Nov 20, 2001
    77
    Well... For now... I will be moving the cable box on top of the receiver... and move the VCR and DVD on the top shelf... I noticed that the DVD doesn't get hot... the VCR that is only when needed... and at that time, obviously, the DVD will be off... so those two shouldn't effect each other...
    Now the receiver get's hot... and the Cable box get's hotter than that... so, they must not mind heat!!! [​IMG]
    I think this is my only solution for now..
    Bill
  7. Allan
    Allan Stunt Coordinator
    Oct 1, 2000
    205
    Ideally nothing should be on top of anyhting else. However, if you must, then you should put your receiver on top of another component. (in your case, probably your DVD player since the cable box and vcr are probably too small.) This will likely not cause any harm and, in any event, is better than placing anything on top of your receiver.
    Allan
  8. Bill Johnston
    Nov 20, 2001
    77
    Well, the cable box is as wide as the DVD and Receiver... But... NONE of them are the right depth!!!
    Unfortunatly, we don't live in a Ideal world... Ever notice that Onkyo and Kenwood (and other's) put DVD's on top of their receivers when taking photos for advertisments and brochures...
  9. Mark Austin
    Mark Austin Supporting Actor
    Dec 28, 1999
    639
    Placing anything on top of your receiver is asking for trouble.
  10. Michael Reuben
    Michael Reuben Studio Mogul
    Feb 12, 1998
    21,763
    2
