Panasonic DMR-E80H Remote Question
Discussion in 'Playback Devices' started by Tommy G, Aug 24, 2005.
  1. Tommy G
    Tommy G Screenwriter
    Sep 19, 2000
    1,233
    I hope this will be a simple question. I bought the above DVD recorder but without a remote. I was wondering if I should get a replacement one or if my dishnetwork remote would work. If it doesn't work, is there a better solution than simply replacing the manufacturer's remote. Thanks in advance.
  2. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    On most DVD Recorders, & depending on the model, you just can't do certain things without the original remote control. I would spend the $40 or so & get one. You can order one from Panasonic's website under PARTS. But if you also din't get the Owners Manual for it that can be download from Panasonic's website under CUSTOMER SUPPORT.
  3. Tommy G
    Sep 19, 2000
    1,233
    Thanks a lot Bill. I'll give it a try.
