kyri
- Mar 10, 2002
I have a question between which one of those two HDTV's are better? I looked at the web for reviews but found nothing and the salesreps of electronics shops have not been useful at all. After looking at the specifications I found the following main specifications but since I am not that knowledgable on the matter would like to hear your
opinion on one or both of the models?
Toshiba: I.D.S.C II, New Hyper Progressive Scanning
New Cinema Mode (3:2 pulldown switch)
New 16:9 Modes (compression and Letterbox)
Digital Comb Filter with Vertical Contour Correction 3D Y/C
Advanced Velocity Scan Modulation
Dynamic Quadruple focus
Black Level Expander
Speaker System: DB
Sub Bass System (SBS)
Cyclone Sub-Woofer System
Audio Wattage 33W
2 Rear A/V Inputs
2 Rear S-Video Inputs
2 Color Stream HD HIGH RESOLUTION Component
VideoInputs
2 RF Inputs
Panasonic: Digital Comb Filter 3D Y/C
Horizontal/Vertical Edge Correction
Digital Velocity Modulated Scan
Fine Pitch Picture Tube
Color Transient Improvement
ID-1 Detection (for anamorphic DVD)
Motion Vector Detection
Progressive Cinema Scan
Progressive Scan Doubler (31.5 kHz -480p)
Artificial Intelligence Sound
Bass/Treble Balance Controls
Dome Sound System
2 Speakers
15W per channel
3 Rear, 1 Front A/V Inputs
2 Rear, 1 Front, S-Video Inputs
2 Component Video Inputs
I ALSO HEARD THAT PANASONIC HAS GEOMTRY PROBLEMS AND THE SOUND IS NOT THAT GOOD...
Looking forward to your comments/opinions.
Speaker System: DB
Audio Wattage 33W
2 Rear A/V Inputs
VideoInputs
2 RF Inputs
Dome Sound System
2 Speakers
15W per channel
