Sam Pat
- Jun 15, 2003
Yesterday, I decided that I needed a 64 Pt, service menu convergence on my ~1 yr old Panny PT47WX42. I could see fringing on alot of sections and the User menu 9pt wasn't sufficient at all.
I did my research on the Panny.tv site, reading the guides, reading the service manuals, reading all relevant posts and began my work.
I started on the COARSE convergence first (with options Size, Screen location, Skewing, and other warping options). I wanted to fix another problem I had (which was the right edge not lining up on some viewing material). I played with the controls till I got it right. Of course, I had written down all initial settings before proceeding.
Then I went to the fine convergence. Lining everything up so the grid looked straight and even to my eyes. I don't have AVIA or VE (just THX Optimizer) and I also didn't print out a grid. I did everything by educated estimation.
When I was done, the image looked very sharp, but I had a few problems.
1.) I noticed that the top, horizontal edge of my screen had some line bending. Straight vertical lines would be bent towards the top 2 inches or so of the screen. It's not atrocious, but noticeable when you looked there.
2.) A portion of the THX Optimizer has two rectangular boxes that frame your viewing area. The vertical lines of the outer box were not perfectly straight. It had squiggles! They looked hand-drawn.
So there are a few things that's on my mind.
Regarding problem 1: This bending was probably a result of me messing with the COARSE convergence. Thankfully, I wrote all initial settings so I went back and put them back. The bending was much reduced, but still there. So this means they were there when I got the set? Does this make sense to you guys? I don't think fine convergence, which is just lining up the 3 guns to grids, could've caused bending. My grid was made perfectly straight, to my eyes. Of course when I reset the values I had to do fine convergence all over again.
Regarding problem 2: My squiggly lines. Was the squiggly lines caused by my FINE convergence (lining up grids) not done well enough? Should I print out a grid (to tape to the set) to get everything perfect? My estimation looked very, very good. I haven't noticed anything with real material (not test images) but it still bothers me that it's not perfect.
What advice can you guys give me? How should I proceed?
I know this is more appropriate on the Panny.tv forums but it wouldn't let me log in. I registered (which was successful) and tried logging in. It would say "Thanks for logging in" but I wasn't actually. If I tried to post, it would ask me to log in with the same thing happening ad infinitum. I emailed the mod (Panny) and his email bounced. I emailed the addy on the main page under "Contact" and it also bounced. They just don't want me on there. :frowning:
Thanks for any help you can give me.
EDIT: Was able to log on to Panny.tv forums now.
