Bill K
- Apr 15, 2000
I need some help.
I've had the Panasonic 53wx42 for 3 weeks now and I've only done user menu tweaks and Video Essentials (wanted the set to settle). Before I venture into the Service menu, I thought I'd ask your opinion on some problems I have.
I'm playing DVD's on the Panasonic RP82 with Monster Component cables. The player is set to darker in Cinema 1 mode (someone here said Cinema 1 produced less edge enhancement, and lighter was, well, too light).
The problem is that the blacks in progressive mode seem brownish, and using VE, I can't get a good dark setting no matter how much I tweak the brightness and contrast levels(I lose way too much detail when black gets black). Also, only on the pluge pattern, I see a white ghost blur in the middle of the screen (popping in a THX Optimizer THX pluge test I don't see the white blur).
I also am finding images (faces, hair, fabrics) are losing their texture and becoming a smear of color in high contrast images. I think this is partly due to bad compression, but my current set up is really enhancing it. Of course, I'm very picky and most people don't see these problems unless I point them out. But now that I've pointed them out, girlfriend sees them all the time too.
I would love to hear what you all think might be the cause of my issues above. Can I fix these in the Service menu? This TV is under warranty and I'd hate to void that by poking thru the Service menu, when the TV might need to be replaced. Also, I intend to get it ISF'd but I don't want someone to come and not be able to fix the problems.
My current settings, which are in the general range of others with this TV, include: sharpness-0, SVM-off, Video NR-on, color temp-normal, natural color-off (on didn't seem to change anything), color matrix-SD (HD didn't seem to change anything).
Thanks Fellas,
Bill
Thanks Fellas,
Bill
