Panasonic 53" hdtv widescreen cleaning
Discussion in 'Displays' started by Jordan Herzlich, Jun 13, 2005.
  1. Jordan Herzlich
    Jordan Herzlich Auditioning
    Mar 12, 2004
    6
    I was wondering if anyone can help me. I have had a Panasonic 53" widescreen hdtv - not lcd or plasma that has its video input from a Cablevision Scientific Atlanta Explorer hdtv box. The tv is around 2 and a half years old. I have noticed that the picture is getting a little fuzzy and I want to correct this.
    I have a 42" LCD Sony that I got recently and with the lcd there is a bulb that is to be replaced every 2 years or so. If anyone can recommend the best way I can "clean" my hdtv- non lcd picture through either a bulb replacement or opening the back of the tv and dusting the internal back of the set I would appreciate it.
    Right now the high def channels still look good but the analog channels are somewhat fuzzy and I think there has to be some cleaning method with a hdtv set almost 3 years old. Thanks in advance for any help.
    Jordan
  2. Michael TLV
    Mar 16, 2000
    2,909
    Calgary, Alberta
    Michael Chen
    Greetings
    YOu provided your own answer. Open up the back and dust it yourself.
    May also want to do a convergence of the image ... service level of course.
    Regards
  3. Jordan Herzlich
    Mar 12, 2004
    6
    Michael, what do you mean by Service level request for the convergence?
    Thanks, Jordan
  4. PeterK
    PeterK Supporting Actor
    Jan 14, 2004
    519
    i believe that means the manual, multi point convergence, as opposed to just pressing the converge button, and doing it automatically.
    I will second that convergence too! auto converge is crap, you gotta do it yourself
