Thong Kha
- Nov 3, 1999
I have a Panasonic PT-47WX51 and before I start I know I made a BIG mistake by not writing down my service mode settings, but here's my situation:
1) Went into service mode to adjust VLIN setting (I've went into service mode many times without problems before this).
2) Adjusted setting accordingly.
3) Now this is where I did something wrong. I pressed the ACTION button and the POWER button together to get out of service mode. Before the TV turned off, I saw something like "SELF CHECK ..." flash on the screen and then the TV turned off. When it turned back on, I had this weird screen that I've never seen before come up. I have a screenshot of what comes up at:
Link Removed
After that happened, all my settings were reset! Even my picture settings and input settings, everything, has been reset. If I go into the service mode to do any changes, and try to exit, the same course of events happens again (self check before TV turns off, then that screen comes on when the TV comes back on), and all my settings are reset again. I can't believe what I've done and don't know what to do.
Is my TV damaged somehow that it doesn't exit out of service mode correctly anymore? My picture looks abosolutely horrible now with bowing and misalignment everywhere since all my settings have been reset to who knows what. Convergence is abysmal and the focus is way off (probably cause of the convergence). Can an ISF technician fix this? Any help would be appreciated.
Link Removed
